Activity Forums Adobe After Effects NTSC for a PAL kind of gal
  • NTSC for a PAL kind of gal
    Posted by Al on June 25, 2009 at 12:55 pm
    does anyone have a title safe guideline for NTSC? i’ve got 720 x 486 footage to work with, and i’m coming from a PAL background. google isn’t helping!
    also, when i make my 16:9 graphics in pal, I always have my comp set to 1024×576 because i prefer to see them crisp when working. when outputting i’ll make them 720×576 so the editors are happy to import.
    but what’s the NTSC equivalent of doing this? By default AE is making my comp D1/DV NTSC (.09) but i’d prefer to work square while getting my graphics right. can i work square, then output my (graphics only) 720×486?
    thanks guys, any thoughts appreciated.
    Al replied 17 years, 2 months ago 2 Members · 3 Replies
  • Alex Dinnin
    June 25, 2009 at 1:41 pm
    When you create a new composition..
    you can choose NTSC D1 Widescreen square pixels.
    the cage should match this as well.. just press ‘ or the title safe button in the composition window
    good luck
    Alex
  • Al
    June 25, 2009 at 9:04 pm
    hey dave, thanks for the reply.
    i’ll be outputting targa seq only > so my plan was to work square pixel and then render 720×486. wasn’t going to pre-comp; do u think this is necessary? when i work with pal i just work square and render 720×576 without a hitch (?)
    thanks for field tips too; need to check this!
  • Al
    June 26, 2009 at 8:01 am
    hey dave,
    sorry my fault, let’s rewind! i was talking about two seperate things, but looking from the second half of your post you see what i’m getting at.
    yes, i work in a comp 1024×576 and when rendering, i put the output module to 720×576. i know this isn’t the common way of doing it, but to be honest i’ve been doing it for years and i’ve *never* had any issues with it (all broadcast)
    i just can’t fathom working on my graphics in non-square pixel 720×576 comp and having the option of either a) viewing it crisp, but squashed or b) viewing it in the right aspect, but un-crisp.
    that just doesn’t make sense to me!
    so i’m going against the grain and working 1024×576 –> but until i see an issue myself i don’t see why not. you see, i’m the person who touches the kettle, then burns myself 🙂
    SO i guess i’m wondering if i can work the same way with my NTSC project, and the answer looks like it’s going to be No, because it’s No to PAL – but looks like i might be trying anyway…?!
