Activity › Forums › Apple Final Cut Pro Legacy › NTSC DVCam import – scanlines?
  • NTSC DVCam import – scanlines?
    Posted by James Smith on November 24, 2010 at 2:11 pm
    I’m working a on a project, where I’m likely to be using source material on NTSC DVCAM ( 720 x 480, 29.97fps). In the end it’ll be mixed with other formats so not sure how it’ll end up, but, any pointers for best way to import into FCP and avoid scanlines as appear at the moment (pic below)? Right now I import using DV-NTSC preset.
    The end project will be solely for web streaming.
    I attached an example of the lines here.
    Paul Jay replied 15 years, 10 months ago 4 Members · 4 Replies
  • Michael Sacci
    November 24, 2010 at 4:25 pm
    To judge your image in FCP you should be using an external monitor, if you do not have one you at least have to set your canvas or view to 100%, even if the image does not fit that is the only way you can see the real image.
    As far as capturing it, unless you have a DV deck with Analog or Digital outs and a video card to capture to there is no other setting. IF you are using FW you have to use DV preset.
  • James Smith
    November 24, 2010 at 4:27 pm
    Thankyou for the reply. I am using an external 24″ monitor and viewing the clip at 100%.
    Understood about using the DV preset.
    Is it actually a case that I have to remove these lines by some processing? Should I be looking into de-interlacing, and is this necessary for web video (or will these lines disappear once uploaded and streaming?)
  • Shane Ross
    November 24, 2010 at 4:54 pm
    By external monitor, he means NOT a computer monitor. HDTV or production monitor, as they display interlacing properly. But, you said this is for the web, which doesn’t like interlacing. So simply deinterlace your footage. Or in the sequence settings, set field dominance to 0.
  • Paul Jay
    November 24, 2010 at 7:43 pm
    Set Sequence settings field dominance to NONE.
    And deinterlace your footage.
    Or edit interlaced and deinterlace on output.
