Activity › Forums › Apple Final Cut Pro Legacy › NTSC DVcam capture – sometimes bars added, sometimes not?
  • NTSC DVcam capture – sometimes bars added, sometimes not?
    Posted by James Smith on November 25, 2010 at 12:33 pm
    I have been capturing NTSC footage from DVCAM tapes. I’ve done four captures now, all using the DV-NTSC capture preset. They have come out with black bars on the top and bottom (as I suppose it should..to be widescreen format?)
    However I have just captured another, and for some reason (same format..) it stretched the image to fill the whole frame.
    Any idea what might have caused this considering I didn’t change any settings? And how should I re-capture in the same way as the other clips, i.e. with bars, widescreen?
    Pics attached here to show difference.
    Rafael Amador replied 15 years, 10 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 25, 2010 at 6:42 pm
    The top picture shows Anamorphic stuff on a 4×3 sequence.
    The second picture shows 4×3 (maybe Anamorphic footage not recognized as Anamorphic) on a 4x3sequence.
    What is supposed you are editing, 16×9 footage?
    Mixed 4×3 with 16×9?
    Do the pictures look distorted on the Viewer?
    rafael
    http://www.nagavideo.com
