Activity › Forums › AJA Video Systems › now I’ve seen it all
Posted by Bob Zelin on January 27, 2008 at 6:44 pmArnie Schlissel replied 18 years, 8 months ago 3 Members · 5 Replies -
Arnie Schlissel
January 28, 2008 at 6:10 pmFrom Markertek: “This well designed, solution based breakout panel brings the connections of your IO HD to the front of your rack in one 2RU panel.”
Because it would be so hard to simply turn the Io HD around in the rack to face the connectors out in the first place…
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Arnie Schlissel
January 28, 2008 at 6:19 pmI should have looked at your 2nd post before posting my ignorant reply above.
How could I have been so naive? So clueless? So dim?
You need to use these 2 rack mounts together. They’re perfect companions. This way you can have both the connectors and the flashing lights facing out on the rack!
Arnie
Arnie Schlissel
January 30, 2008 at 6:47 pmThe perfect companion, a rackmount for your iPod!
Arnie
