Activity Forums Apple Final Cut Pro Legacy Now I see why they call it ‘Media Mangler’
  • Now I see why they call it ‘Media Mangler’
    Posted by Bob Roberts on January 18, 2008 at 8:50 pm
    So, I’m cutting a music video on my MacBook Pro shot in HD that wants to finish in HD. As you would expect, lots of multicam…between 4-9 takes per setup. Fine, I’ll just media manage my project from 1080 DVCProHD down to anamorphic DV, cut like crazy, re-media manage to create a HD copy, reconnect media, and voila…right?
    I’d say about 10% of the project actually linked back up from “offline” to it’s original “online” source. The main culprit seemed to be using multiclips. When I went back to my original DV edit and collapsed all the multiclips, every thing linked back o.k…but ofcourse without the functionality of actually having the mulitclips. Obviously not so good.
    This is the first time I’ve ever tried to do an Online(HD)/Offline(SD) workflow specifically with mulitclips using the Media Manager…any suggestions?
    Thanks in advance.
    Erich Hoberg replied 18 years, 7 months ago 8 Members · 10 Replies
  • 10 Replies
  • Mark Raudonis
    January 18, 2008 at 9:46 pm
    Bob,
    You’re NOT imaginining things.
    Media manager and multiclip are NOT friends.
    You’re correct that the work around is to go back and “cut in ” the original media.
    I don’t know a solution for this other than that. Perhaps someone else can chime in.
    Mark
  • Bob Roberts
    January 18, 2008 at 9:55 pm
    For sake of not completely bashing MM…I use an Online(SD)/Offline(SD) with multiclips for music videos all the time:
    1) Digitize tapes at SD NTSC, 10-bit Uncompressed
    2) MM to DV
    3) cut
    4) MM and reconnect back to 10-bit Uncompressed
    No problems…so, go figure with HD/SD.
  • Mark Raudonis
    January 18, 2008 at 10:41 pm
    I think the issue here is NOT HD to SD, but multiclipping.
    We use MM everyday too. We’ve just got to do a LOT of manual workarounds ’cause nearly all of our stuff is multiclipping.
    Mark
  • Bob Flood
    January 18, 2008 at 11:31 pm
    Bob
    dont “re media manage to back to HD” just copy your timeline over to the HD edit system, and reconnect the timeline media
    then copy all the clips from the dv timeline to an HD timeline so the source media and timeline match
    what i do is i use multiclip to get my first cut down, usually pretty tight. but then its faster for me to back load clips and gang em, or just look at cameras straight.
    soooo you would do all your multiclip editing at dv, get it pretty locked up, then collapse your clips, reconnect to HD, and any more ediitng just do straight (or make new multiclips)
    at least that should work better than 10 percent
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Pat Defilippo
    January 18, 2008 at 11:35 pm
    Hello,
    Just a thought – have you tried “collapse multiclip” to the one angle you want before going into the mangler? That pretty much chooses the one angle out of the however-many-you-had and helps reduce dropped frames during playback, anyway. The multiclip does keep your unused angles, so you can go back later and “un-collapse” if you need to.
    I don’t know if this might be your answer or not – I haven’t tried it myself before MM. Just select all of your multiclips, right click and select “collapse multiclip”. Then, try the mangler and see if that helps.
    Good luck,
    -Pat
    G5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
    30″ Cinema Display & 17″ Sony SVGA ~
    Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
    AJA Io LA ~
    Final Cut Studio 2 ~
    Sony UVW-1800 Beta-SP ~
    Sony DSR-40 DVCam ~
    2.33ghz MacBook Pro 17″ (with FCS2) ~~~
    P D Post Productions, Inc. ~
    TV~DVD~VHS~CD~WEB
    for Corporate Communications, Commercials, Infomercials, Television Programs and Family Occasions since 1983 ~
    E-mail PD@PDPost.com ~
    Website http://www.PDPost.com ~
    Business/Cell Phone (847) 275-5671
  • David Mcclellan
    January 19, 2008 at 7:14 pm
    You are not alone in your grief – I just tried to media manage a very long training DVD that was ALL multi clips – and FCP completely lost it on 2 of the sequences. I guess that is pretty good considering that there were 15 or 16 sequences. I have no idea why – as they were all cut in the same fashion with 3 camera setups and then collapsed. I was just trying to move the media to a backup LaCie FW Drive to take to client for approval – so my original clips were still intact – however I am wary of Media Manager because – to paraphrase the great Will Farrell “80 percent of the time it works every time…” Words to media Manage by.
    -DM
    G5 Dual 2.5Ghz
    OSX4 FCS 6
    Lots of Ram – Lots of cables – Lots of bills…
  • Mark Raudonis
    January 19, 2008 at 10:18 pm
    [David M.] “all cut in the same fashion with 3 camera setups and then collapsed.”
    I’ve found that collapsing is often not enough. You have to actually replace, shot by shot the multiclip with it’s corresponding “original” angle. Do that, and the results are predictable. Don’t do it and it’s anyone’s guess.
    Yes, this takes a very long time to do, but it may be the only thing that works dependably.
    Mark
  • Tom Wolsky
    January 19, 2008 at 10:42 pm
    Does it work properly if you drag the sequence into a new project?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Josh Hatter
    January 21, 2008 at 8:00 pm
    We had no problems with multiclip Media Managed projects in FCP 5.1.4, then it stopped working properly in 6.0.1, and is back to being fully functional for us in 6.0.2. We MM DVCPro HD and XDCam multiclip shows, nothing less than 30 min.
    Symptoms would be not having the right part of a master clip in the timeline, audio sync issues, just a messy messy deadline missing experience.
    I havent heard any complaints since the upgrade to 6.0.2.
    Good luck and sorry for the pain.
    Josh Hatter
    HDNet Engineering
  • Erich Hoberg
    February 8, 2008 at 12:24 am
    I know I’m jumping in this a little late, but I just got involved with a DVcProHD project requiring a 6 angle multiclip that I am thinking of editing offline. My initial reaction is to down convert the hd footage through my aja kona 3, edit the multicam sequences, delete (or move) the dv clips, then recapture the timeline at full resolution. That should work in theory right? What you guys are saying is that it doesn’t though because it loses the multicam cuts? Or is that only an issue going through the media manager?
    Erich Hoberg
    iEdit Creative
    FCP 6.0.2
