Activity › Forums › DaVinci Resolve › now every time I restart the CUDA is not recognized
Posted by Andrew Sableton on February 22, 2012 at 5:56 pmWhenever I restart my computer the CUDA is not working again. I need to reinstall every time I restart – then it works fine.
I have installed it both from the ADMIN user account and my usual working account and it makes no difference.
Any suggestions…..?
AS
Tyler Johnson replied 12 years, 6 months ago 5 Members · 6 Replies -
Andrew Sableton
February 22, 2012 at 7:29 pmNever mind, got it working. For some reason the /System/Library/StartupItems folder was not owned by the root account so the CUDA.kext driver was not loading at startup. “sudo chown root:wheel /System/Library/StartupItems” fixed it.
John Michaels
February 23, 2012 at 12:42 amThanks for taking the time to post your solution. I’m mostly on Windows, but whenever I’m on Mac OS X I seem to have some kind of trouble with CUDA, so it’s good to have another thing to try.
Timothy Kendall
July 10, 2013 at 3:10 amI’m having the same issue and have scoured the internet until now. I’m a bit of a newbie on how to operate your fix. Could you PRETTY PLEASE break it down for me? I would humbly appreciate any help.
Timothy Kendall
July 10, 2013 at 3:26 amYOU’RE THE BEST! I was searching forever for this solution and you got it. Was about to drop kick my system into the LA River. But now I can use it. THANK YOU
Robert Ober
July 30, 2013 at 11:31 pm[andrew sableton] ” Never mind, got it working. For some reason the /System/Library/StartupItems folder was not owned by the root account so the CUDA.kext driver was not loading at startup. “sudo chown root:wheel /System/Library/StartupItems” fixed it.”
Solved my issue with 9.1.5 as well.
Robert A. Ober -
Tyler Johnson
March 11, 2014 at 4:02 pmCan someone explain how to fix this CUDA problem with kexts? I don’t know to much about editing these files. Thank You
