Activity › Forums › Adobe Premiere Pro › Novation Launch Control Premiere Pro
Posted by Apostolos Troiker on May 29, 2024 at 12:54 amHow can i use Novation Launch Control xl to control Adobe Premiere Pro parameters?
Mads Nybo jørgensen replied 2 years, 3 months ago 3 Members · 2 Replies -
Hector Vera
May 29, 2024 at 2:29 amNot sure if this video will help find exactly what you are looking for but I found this video which shows the Novation launch Control to be used in Adobe Premiere Pro. https://www.youtube.com/watch?v=fgV2hT0IXNg
Hopefully it helps you in some ways! 🙂
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Mads Nybo jørgensen
May 29, 2024 at 9:06 amHey Apostolos,
Must admit that I was surprised to find that Audition does not have midi control, which would have been an obvious step.
As Hector suggested, check out the Mackie connection interface.
Reading up on the Novation Launch Control specs, at the bottom of the “small print” it says:
“Control Cubase, Logic Pro and Pro Tools – full support for Mackie’s HUI
protocol allows you to control other DAWs with Launch Control”So you should be fine to go.
https://novationmusic.com/products/launch-control-xl-refurbished
novationmusic.com
Launch Control XL - Refurbished
Ultimate controller for Ableton Live with 16 buttons, 24 knobs and eight faders, all integrate with Live.
