Nothing is rendering realtime in Final Cut Pro
Whenever I bring a clip into the timeline I get that annoying orange bar and the clip drops frames when I playback. I’m new to Macs and FinalCut but I’m sure I should be able to play at least base clips realtime. I’m running Final Cut Pro 5.1.1 on a Quad PowerPC G5 with 4.5 GB of Ram and a 1.8 TB SATA Raid drive. I’m pretty sure I’ve double-checked all of the settings, I’ve given FCP enough ram and the right scratch disks. I’ve got nothing else open and I’ve tried this in an empty project with the defaults applied. I’ve also made sure the sequence settings match the clip settings and I’ve tried the AJA Kona 10bit uncompressed codec and the default FCP 10bit one too and neither will play back realtime. Does anyone out there know what might be wrong with my setup?
