Activity Forums Adobe After Effects Nothing happening on Shatter effect
  • Nothing happening on Shatter effect
    Posted by Brian Jaggers on November 7, 2009 at 6:58 pm
    I am adding the Shatter effect, but all I see is the Waveform mode, or the render mode without any actual movement on the shatter, just a hole in the middle of the picture I’m shattering. What am I not doing? how do I get the shatter to… Shatter.
    Keith Mcgregor replied 16 years, 10 months ago 2 Members · 1 Reply
  • Keith Mcgregor
    November 7, 2009 at 11:35 pm
    Shatter is one of the fx that use the beginning
    of the layer as a start point. So if you are 1 second
    in you won’t see anything. Set view to rendered,
    set render to all, ram preview the first 2 second
    And see it in default action. You will be able
    to modify the start point by animating the radius
    of force 1 or using a gradient map and keying the
    thresh OR animate the origin of force 1.-K
    Reality? What did you make it?
