Activity Forums Apple Final Cut Pro Legacy Nothing but crash—no matter what. Ideas???
  • Nothing but crash—no matter what. Ideas???
    Posted by Phillip Powell on December 3, 2007 at 8:14 am
    Things were going just fine—-
    Until time to output and burn of course. supposed to ship 50 discs tomorrow, and can’t even get past render—
    FC Studio II, 6.0.2, Quad Core 8 Gigs RAM, rendered 1 hr sequence, sent to compressor. Crash. Tried Again, deleted render files, re rendered, crash.
    6 times in various attempts, delted prefs, DiscWarrior and First Aid, Repaired Permissions, same.
    Sequence is DVCProHD 24 P, wondering if the temp stock that’s PAL @ 25 fps in the seq could be culprit?
    Thanks for any ideas, here selections of the crash log:
    Date/Time: 2007-12-02 23:44:14.562 -0800
    OS Version: 10.4.11 (Build 8S2167)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [107]
    Version: 6.0.2 (6.0.2)
    Build Version: 7
    Project Name: FCPApp
    Source Version: 711051055
    PID: 238
    Thread: Unknown
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00052c01
    Thread 0:
    0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7
    1 com.apple.FinalCutPro 0x00423b21 Synchronizable::Wait() + 47
    2 com.apple.FinalCutPro 0x00410406 DisplayQueue::Run() + 702
    3 com.apple.FinalCutPro 0x0044ddb8 Thread::RunHelper(void*) + 20
    4 libSystem.B.dylib 0x90024227 _pthread_body + 84
    Unknown thread crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0xffff5881 ecx: 0x00000000 edx: 0x9001029c
    edi: 0x00000003 esi: 0xfb01c200 ebp: 0x00000003 esp: 0xbfff05b0
    ss: 0x0000001f efl: 0x00010246 eip: 0x99369ab2 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    Binary Images Description:
    0x1000 – 0x74afff com.apple.FinalCutPro 6.0.2 /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xb0a000 – 0xb0dfff KGCore /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xb14000 – 0xb23fff com.apple.AERegistration 1.2 (72) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xb35000 – 0xb3cfff com.apple.AEProfiling 1.2 (18) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xb44000 – 0xb74fff com.apple.AVCVideoServices 1.0 (38) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
    0xb96000 – 0xba7fff com.apple.framework.promedia.ProMediaIOUnit 1.0.0 (1) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOUnit.framework/Versions/A/ProMediaIOUnit
    0xbb4000 – 0xbbcfff com.apple.framework.promediaio 1.0.0 (1) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIO.framework/Versions/A/ProMediaIO
    p2
    Rafael Amador replied 18 years, 9 months ago 2 Members · 3 Replies
  • Rafael Amador
    December 3, 2007 at 10:46 am
    If you can render, try to export a reference or auto-content movie and use Compressor as stand alone.
    Rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Phillip Powell
    December 3, 2007 at 3:01 pm
    let me render the full seq.
    Did get it to render a few trys ago by doing half the seq, then the other. But halfway thru compressor, ‘Final Cut has unexpectedly quit. Do you want to send a report to Apple?’
    p2
  • Rafael Amador
    December 3, 2007 at 3:26 pm
    Is difficult to suggest you any thing new because you have tried everything including DiskWarrior.
    Have you noticed if FC crash when arrive to render a certain moment of the project? This could mean a corrupted file. And the only solution for this is to get rid f that file.A way to check that is to put the media Off-line and try to render.
    In a desperate situation I would try render or export in blocks of few minutes. Then try to put all the pieces together. Having a TC the result would be the same.
    Rafael
