Activity Forums Panasonic Cameras Not your typical firmware update issue…
  • Not your typical firmware update issue…
    Posted by Andrew Saliga on March 24, 2010 at 9:23 pm
    We have an HVX-200 that has been mainly used with miniDV or a FS-100 drive.
    We’ve tried several times in the past to update the firmware to allow higher capacity P2 cards. (This is an old, old update.) This update process has never been successful, so today I looked back into it since the FireStore drive is a pain to work with.
    I downloaded the firmware from Panasonic, added it to an SD card that was freshly formatted in an HVX-200, initiated the menu operations, etc., but the camera will not see the card and give the “Update” option.
    This particular camera wasn’t able to format the SD card, so I formatted it in our other HVX-200 (which has never had a problem with a firmware update). Attempting to format in the troublesome camera gives me the error message “Warning, cannot format!”. The write protect tab is not locked on the SD card.
    Is this a hardware issue? Has anyone experienced this or this there a hidden diagnostic menu of sorts in the HVX?
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
    Andrew Saliga replied 15 years, 4 months ago 7 Members · 22 Replies
  • 22 Replies
  • John Fishback
    March 24, 2010 at 10:13 pm
    I’d check with your dealer. Sounds like a hardware issue of some sort.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Jeremy Garchow
    March 25, 2010 at 12:52 am
    Try a smaller capacity SD card.
  • Andrew Saliga
    March 25, 2010 at 7:19 pm
    I like where your head is. Now just to track one down…
    -Andrew Saliga
  • Jan Crittenden livingston
    March 29, 2010 at 1:25 pm
    Make sure it is an SD card and not an SDHC card.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HPX300, HPX170, HVX200A
    Panasonic Broadcast & TV Systems
  • Andrew Saliga
    March 29, 2010 at 2:41 pm
    Thanks Jan.
    It is indeed an SD card. It’s 1GB, so I’ll try looking around for a smaller capacity card.
    -Andrew Saliga
  • Andrew Saliga
    March 30, 2010 at 3:43 pm
    I’ve since tried a 1GB and a 512MB card, both without any luck. I’ve formatted these cards on my Mac as FAT32 before trying them in the HVX. They read, but will not format. The other HVX reads and formats them.
    -Andrew Saliga
  • Andrew Saliga
    March 30, 2010 at 4:17 pm
    Any chance it’d need to be a card smaller than 512MB?
    I’m hesitant to say it’s hardware because the camera sees the card. When the card is inserted I can perform card “Operations” on it through the menu, but when I remove the card, it’s grayed out as I would expect it to be.
    -Andrew Saliga
  • Jeremy Garchow
    March 30, 2010 at 4:23 pm
    [Andrew Saliga] “Any chance it’d need to be a card smaller than 512MB? “
    Yes.
  • Gary Adcock
    March 30, 2010 at 7:14 pm
    if I remember correctly- the HVX manual states the SD card needs to be something less that 64MB but it has been awhile since I looked.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Andrew Saliga
    March 30, 2010 at 7:16 pm
    I was thinking along those lines, but I looked it up. 8MB-1GB supported.
    -Andrew Saliga
Page 1 of 3
