Activity Forums Adobe After Effects Expressions Not sure what is happening!! Please take a look.
  • Mylenium
    January 14, 2006 at 9:56 pm
    Since your pic only shows the timeline, I won’t comment on any of the design problems you mentioned, but your ramp can be made to follow your adjustment layer using expression. Try something like this on the ramp’s crosshairs:
    adjuster=thisComp.layer(“Adjustment Layer 2”).position;
    X=value[0];
    Y=adjuster[1]+value[1];
    [X,Y]
    Mylenium
    [Pour Myl
  • Captain Mench
    January 14, 2006 at 10:10 pm
    Thanks… giving it a try.
    Did you see the movie? When I typed in the link it didn’t show as a hyper link…
    https://homepage.mac.com/captmench/TBLogoColorMove.mp4
    Thanks again.
    CaptM
  • Derrick
    January 15, 2006 at 8:48 am
    If you’ve got the 6.5 Pro version, through some ZAXWERKS 3d Invig on the text, (if you’ve got CorelDraw of Illustrator to create vector graphs), will give more dimension to the comp perhaps? With that you can create the whole look of the text anyway, so no more adjustment layer.
    Plus a hint of a light in the 3D comp inside the box could also add to realism?
    A sine wave type movement should give you a better floating effect? I think, haven’t tried it, just a thought.
    Hope I’m not talking to much bullocks hie hie, makes sense to me though!
    – Derrick
