Activity Forums VEGAS Pro Not rendering without quality loss
  • Not rendering without quality loss
    Posted by David Vandenbulcke on February 8, 2009 at 12:40 am
    Hello all 🙂
    I’ve been surfing through various topics on this board & trying to find a solution for this for about 2 days now & it’s really starting to do my head in cuz I can’t seem to find the solution for it..
    Whenever I render one of my vegas projects they end up with kind of a blur/ghost around it.. which is not the case in my original file..
    I’ve tried almost every different format & template but the result is always the same.. I can’t seem to get rid of the ghost..
    Free Image Hosting at www.ImageShack.us
    I hope anyone can help..
    Sorry if I overlooked the answer in this forum!
    Thanks in advance!
    David.
    David Vandenbulcke replied 17 years, 7 months ago 2 Members · 2 Replies
  • Danny Hays
    February 8, 2009 at 1:06 pm
    That looks like you rendered as progressive and that frame is showing the “Blend” of the lower and uper fields. Not every frame is like that is it? Danny
  • David Vandenbulcke
    February 8, 2009 at 7:13 pm
    Well, most of the frames seem to be like that.. every object that moves close to the camera looks like this.. If I play the movie you can clearly see it as some sort of white ghost/blur around the persons.. The effect on far away objects seems less, but it’s there cuz it’s not 100% sharp..
    I’ve tried most of the standard Templates & a couple of custom ones with every Field order so far.. (lower, upper, progressive) & it all seems to have the same result..
    As soon as I start to render, I can follow the progress in the preview window & there I can already see the ghost/blur..
    I’m confused why there’s not even 1 standard rendering Template that does the trick.. (I’m using Vegas Pro 8 btw)
