Activity › Forums › Adobe Premiere Pro › Not recognizing sound
  • Not recognizing sound
    Posted by Marvin Bek on July 27, 2012 at 11:12 pm
    So i was going to cut out a bit of a Family Guy episode for my iPod (ad there’s a funny scene there) but the audio doesn’t show up. I tried with Sony Vegas as well, didn’t work. I don’t really have much info, but i have the MediaInfo dump:
    General
    Complete name : I:\Medier\TV – Kopi\Family Guy\Season 7\FamilyGuy.s07e02.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 174 MiB
    Duration : 24mn 47s
    Overall bit rate : 983 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 2
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (MPEG)
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 24mn 47s
    Bit rate : 526 Kbps
    Width : 576 pixels
    Height : 432 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.088
    Stream size : 93.3 MiB (53%)
    Writing library : XviD 1.1.2 (UTC 2006-11-01)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : 2000
    Duration : 24mn 47s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 79.4 MiB (46%)
    Alignment : Split accross interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
    Why doesn’t anything recognize the audio? (XBMC does, but only if i put the HDMI audio output to Analog, don’t know why)
    Norman Greenwood replied 14 years, 1 month ago 2 Members · 1 Reply
  • Norman Greenwood
    August 13, 2012 at 5:37 pm
    Hmm. How did you obtain the clip (e.g. YouTube, recording, etc.)? When you look at the audio is it blank or does it give waveforms? If you play it normally, does the audio work?
    I would do one of two things, without knowing the answers to my questions, find the clip on a place like YouTube and get it from there. Or, convert the video to a different format and try seeing if that works.
