Activity Forums Apple Motion not open the windows (file browser, library and inspector
  • not open the windows (file browser, library and inspector
    Posted by Diogo Santo on June 30, 2008 at 1:34 pm
    hello, i have a macbook 2.16 GHz with 1 GB DDR and i install the new final cut studio 2 ( upgrade ), and I have a unique problem, my motion not open the windows ( file browser, library and inspector) the others windows open ( timeline viewer),is strange, i already unnistall the fco and installed,
    I need of your help.
    Thank you
    Jacobo Hernandez replied 13 years, 11 months ago 7 Members · 10 Replies
  • 10 Replies
  • Ann Clark
    July 21, 2008 at 11:14 pm
    I just noticed this problem today. The file browser, library and inspector panes are gone and cannot be opened via the Window menu or the buttons.
    Additionally, when I open Motion, no other windows appear. Even if I selected a template to start with, it does not open, unless I go back and re-select it from the list.
    I was working with Motion all day today and yesterday with no problem. Then the next time I accessed the program, no windows (as described above).
    I am running a MacPro, Leopard, and Motion 3.0.2. I ran Disk Utility and repaired permissions. No change with Motion.
    Has anyone else found a reason/solution for this problem?
    Thanks.
  • Chris Dixon
    July 23, 2008 at 3:26 pm
    Trashing the prefs fixed it.
    Here’s another post about the problem on apple board.
    https://discussions.apple.com/thread.jspa?messageID=6658594
  • Ann Clark
    July 23, 2008 at 7:10 pm
    Thank you.
    Trashing the prefs fixed it for my Mac Pro machine, too.
    For anyone else who runs into this problem, the file to trash is:
    com.apple.motion.plist
    in
    Users//Library/Preferences folder.
    This may not work for everyone, but I’d recommend trying it if Motion won’t open some windows.
  • Dan Riley
    August 8, 2008 at 5:30 pm
    Thanks Ann.
    Had the problem on startup today. Did a cow search, found your post,
    did as you said, fixed it.
    Have a great day.
    Dan
  • Bret Williams
    August 15, 2008 at 7:18 pm
    Ditto. Thanks!
  • Jaap Van willigen
    September 10, 2010 at 6:17 am
    THX a million Ann. It also solved my problem!
  • Jacobo Hernandez
    October 11, 2012 at 6:33 am
    i can’t find the folder, where is it? please help!!!!!
  • Ann Clark
    October 15, 2012 at 6:11 pm
    It should be easy to spot of you do this:
    Go to your Macintosh HD,
    open Users
    open Library
    scroll down till you see the file: com.apple.motion.plist
    You might also just do a search for the file.
    Then again, if you’re not the Admin on your laptop, perhaps you can’t see this file? Hm.
    Try the above, and let us know if you find the file.
    – Ann
    MacPro 2 x 2.8 GHz Quad-Core Intel Xeon 14GB memory – OSX10.6.8 FCP7
  • Ann Clark
    October 15, 2012 at 6:20 pm
    open Users
    open Library
    open Preferences
    – Ann
  • Jacobo Hernandez
    October 16, 2012 at 5:26 am
    Your right about the folder, i can’t see the file com.apple.motion.plist.
    i have an i mac and I’m the admin.
    i downloaded motion 5. problem solved
