Activity Forums Apple Final Cut Pro Legacy NOT FOUND/ General Error Alert
  • NOT FOUND/ General Error Alert
    Posted by Buddy Unidas on April 20, 2006 at 6:27 am
    What does this mean? Whenever I get to a certain part in my tiimeline, I always get this warning and I can’t play that section. I can export an MPEG2 but I can’t export any type of audio without crashing FCP. Is this corruption in one of my files? I checked my hard drive and it seems okay. I tried trashing prefs, but still does it. I’m so confussed and frustrated. Any ideas?
    Bud
    Don Greening replied 20 years, 4 months ago 2 Members · 3 Replies
  • Don Greening
    April 20, 2006 at 6:34 am
    Try trashing your audio render files. You’re right. it does sound like a file corruption and I’d bet it’s a render file. Also, someone a week or two ago had a similar situation where a FCP audio plugin they were using caused havoc with a QT export. You may want to check your timline to see if you’ve used an audio plugin that you haven’t used before.
    – Don
  • Buddy Unidas
    April 20, 2006 at 6:51 am
    That Worked. Thanks for your lightning fast reply. You’re the bomb!
    bud
  • Don Greening
    April 20, 2006 at 6:56 am
    Welcome 🙂
    – Don
