Activity › Forums › Apple Final Cut Pro Legacy › “Not Found” and “General Error”
Janani Noia
January 26, 2012 at 6:45 pmwell, they should…I did, and look where it got me!
thanks again…for the help and the laughs. -
Phillip Large
March 4, 2012 at 5:21 pmI have the same problem many have before “Not Found”. This is new to me and one that I have never seen before. I followed everyone’s blogs but my situation is perhaps unique. I travel and have so many different clients that I have external drives for each. So my project has always originated on an external drive. However, my renders were going to my internal drive. So I deleted all my renders and moved everything to the external drive, and, I am still getting this “Not Found” error.
The only thing I can think of is that I created this sequence beginning with modifying the timecode of the sources to match the counter times that the clients notes reflect. At one point during the edit I changed the timecode again as I saw it drifted too much. I don’t know why that would not allow a full render?
When I got the error I continued editing and just not rendering. So now my project length is a little over an hour. You can already see the problem in setting up a render, seeing 3 hours, walking away, and finding the same error message sometime while I was gone.
What’s next? Any help would be appreciated as I have another hour of editing to total a 2 hour project and a ton of rendering now.
thx
