Activity Forums Adobe After Effects Not enough memory error
  • Not enough memory error
    Posted by Dave Simpson on June 13, 2005 at 10:41 pm
    Hello,
    In rendering a sequence I get the following error “Not enough memory to create image buffer
    14053 requested, 821183 avaiable”. I am rendering it with the comp window closed, on a G4
    with 1.2 gigs of ram. IF there is 821183k available, and 14054k requested I’m not sure why the
    render keeps failing. I restart and pick up where I left off, but it fails after rendering about 4 seconds of
    the sequence.
    Any tips would be appreciated.
    Dave Simpson
    Glenn Moore replied 21 years, 3 months ago 3 Members · 4 Replies
  • Sean Freehill
    June 14, 2005 at 3:19 pm
    I’m getting the same thing on my PC dual 3.2 Xeon w/ 2gb ram.. Also looking for answers..
    Thx.
  • Glenn Moore
    June 14, 2005 at 3:23 pm
    Sorry if this is very obvious and it doesn’t address your issue but…..
    Purge your memory first then try it again but you may want to cut the resolution down a bit (half or quarter)with a smaller screen size. A lot of times, people try to render out long stretches of the comp at max resolution. AE isn’t really for that.
  • Dave Simpson
    June 14, 2005 at 4:16 pm
    Thanks for the reply Glenn.
    I did a reboot of the computer after each failure, left the comp window closed, and just
    had AE open while rendering. I assumed the memory was purged at reboot, so
    I’ll try reducing the resolution as an experiment and see how that goes.
    The project is finished now , I just had to do it in several chunks and babysit the
    computer as it rendered (and stopped) ;^)
    Dave
  • Glenn Moore
    June 14, 2005 at 4:21 pm
    A simpler purge is the Purge (All) option in the menu under Edit I believe. Hope it works out.
