Activity Forums Zaxwerks Not enough memory error
  • Not enough memory error
    Posted by Jonathan Capra on December 15, 2005 at 3:42 am
    Has anyone yet found a fix for the old ‘Not enough memory to complete operation (*6)’ error when clicking Options in 3D Invigorator?
    This is my first foray into 3D Invigorator after a long haitus. I think this happened to me a while ago in the past. At first it seemed like it genuinely was a memory issue, because I could get it to go away by shrinking the resolution of the precomp being used as a texture map.
    But as I progressed, the memory error became more permanent. Luckily I have my animation in a ‘good enough’ state, and it is only 3 seconds out of a 30 second spot, but I was really wanting to make a few more nitpicky tweaks on objects and such. The spot is kinda overdue as it is, but I’d figure I’d post tonight and if anyone had a fix by morning, I’d change it.
    I’m on an WinXP machine with 1.5gig of memory using AE6.5 and I am using Invig PRO. I do have a Macintosh in-house that also has Invigorator, so I don’t know if it might help anything to migrate the whole project to Mac. It might be tricky though, now that I think of it, because I think it has AE 6.0 or AE 5.5 on it.
    Any ideas?
    Jonathan Capra replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
