Activity Forums Zaxwerks not enough memory
  • not enough memory
    Posted by C.kerwin on June 14, 2005 at 6:09 am
    Hello,
    I’m getting the “not enough memory to complete operation (*6)” when I hit the red ball.
    Here’s my numbers:
    AE 6.0, Invig 4.0.4, Windows 2000 Professional, AMD Athlon 2200+, 523800KB RAM (just typing exactly what the display says).
    I’ve pulled up the Task Manager during the operation. Under Mem usage it says 345708K / 1515120K .
    Had used previous invig on AE5.5 and it worked really well.
    Great product, but help me make it work! Ha ha.
    dcwin
    Mark Going replied 21 years ago 4 Members · 5 Replies
  • Serge Hamad
    June 14, 2005 at 6:47 am
    Hi dcwin,
    Just to get you going:
    -Purge your ram in AE or even better use the “Purge all” function the try again to open the Set-Up window.
    -And /or click on the red button several times (it worked for me after two or three times)
    Let us know how it goes.
    Salut.
    Serge
  • Matt Rhodes
    June 14, 2005 at 4:05 pm
    Hi Dcwin.
    Can I assume that you have tried pressing the “Options” button and that you get the same error?
    I’d suggest you test the pre-release version v4.0.5 found here:
    Windows – Invigorator PRO 4.0.5
    https://www.zaxwerks.com/downloads/InvigAEPro4.0.5_060205R.zip
    Let us know if that version is still giving you problems.
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • C.kerwin
    June 14, 2005 at 5:29 pm
    Thanks Serge and Matt!
    I tried clearing the cache before—didn’t help.
    The 4.0.5 worked like a charm though. All is great.
    Not to blow you guys’ horn Matt, but the product is winning over editors I work with who, before now, were a little hesitant with After Effects. It’s so user friendly and powerful, they can’t help but try it and like it.
    Keep up the good work.
    -dcwin
    ps Serge–Turbo squid gave me a different baseball model and it worked like a charm. Sorry I never got back to you!
  • C.kerwin
    -dcwin
  • Mark Going
    August 2, 2005 at 9:30 pm
    I downloaded this zip but my authorization code won’t work for it. It was from 3.0 Pro
