Activity Forums Apple Final Cut Pro Legacy Not connecting to Additional Setups
  • Not connecting to Additional Setups
    Posted by Jim Carswell on August 19, 2010 at 9:29 pm
    Hello all,
    I just received a new MacBook Pro, replacing a damaged 17 inch Macbook Pro. During the set up of the new computer I migrated all of my applications and files from the old MBP. Everything seems to be fine- however Final Cut is not connecting to the Additional Easy Setups folder which contains all of the ProRes setups.
    Any advice on how I can get things working properly?
    Your help is appreciated.
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
    Jeremy Garchow replied 16 years ago 3 Members · 5 Replies
  • John Fishback
    August 19, 2010 at 9:59 pm
    It’s not a good idea to try to migrate pro apps. It’s best to do a clean install.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jim Carswell
    August 19, 2010 at 10:47 pm
    John,
    So, do I just install on top of the applications I migrated or should I uninstall Final Cut and than install the original version and the upgrade version?
    Jim
    Jim Carswell
    Savannah, GA
  • Jeremy Garchow
    August 19, 2010 at 11:08 pm
    Use FCP remover to remove, then install the upgrade. No reason to install the previous version, although you will need the serial number from it.
    Jeremy
  • Jim Carswell
    August 20, 2010 at 8:27 pm
    I followed your advice and used FCS remover and then did a new install from the upgrade disks. The ProRes options still do not appear in my Easy Setups however if I scroll down to Audio and VIdeo Settings the ProRes options are there.
    Jim
    Jim Carswell
    Savannah, GA
  • Jeremy Garchow
    August 20, 2010 at 8:57 pm
    [Jim Carswell] “The ProRes options still do not appear in my Easy Setups”
    Do you have a capture card? There are no ProRes easy setups that come with FCP, except the HDV to ProRes firewire.
