Activity Forums DaVinci Resolve Not able to Read DNxHD
  • Not able to Read DNxHD
    Posted by Robert Due on September 27, 2011 at 11:41 pm
    Hello all,
    Simple problem – hope someone out there has a suggestion. I cannot import any Avid DNxHD QT files. I have purchased the additional DNxHD option to render MXF files for going back to an Avid. I just can’t import any files into the Media Pool.
    Also: I can playback DNxHD files in QuickTime Player or After Effects, etc. So it’s not that I don’t have the codecs installed (I think)
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    Robert Due replied 14 years, 11 months ago 2 Members · 2 Replies
  • Peter Chamberlain
    September 28, 2011 at 4:08 am
    Resolve supports DNxHD in the MXF wrapper. When you say you can’t import any files, I guess you mean DNxHD QT. Can you import DNxHD MXF that Resolve rendered?
    Peter
  • Robert Due
    September 28, 2011 at 2:58 pm
    Yes, I can import a rendered DNxHD MXF output from DaVinci. So basically, DNxHD QTs are not a supported format for import into Resolve?
    Good to know.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
