Activity Forums Adobe Premiere Pro Normal sound quality reduced since last week but only on footage from this year.
  • Normal sound quality reduced since last week but only on footage from this year.
    Posted by Tony Cook on March 25, 2010 at 2:18 am
    Hi! Something strange has recently happened to the audio on some of my video clips. When placed on the timeline every clip uploaded since the beginning of 2010 only shows a sound wave for the R channel, and none for the L channel. As such the sound volume is very low even when whacked up. Every clip uploaded from before beginning of 2010 shows sound waves for R and for L, and the sound is perfect.
    This problem only occured the other week! Previous to this all sound clips uploaded in 2010 had L and R soundwaves and good volume.
    I’ve brought the clips back in from backup copies on a portable hard drive, but all the 2010 backup copies lack a L soundwave.
    I uploaded from the tapes on which the original recording is, and volume plays low during capture, and shows no L soundwave on timeline. New material I’ve shot to see what happens when other footage is uploaded also results in low sound, and no L soundwave.
    The same footage plays at good volume on the camera itself, so I know it’s recorded fine.
    I’ve reset the workspace. No change.
    I’ve started a new non-Matrox project with the 2010 footage. No change.
    I’ve put the 2010 footage on a timeline in Encore. Same low sound.
    Reset PC and left it turned off for periods of time. No change.
    I should also add that the PC with Premier on is not connected to Internet or Intranet. I am definitely the only person who uses it, and I haven’t uploaded any new files or programs recently.
    So I’m left with only being able to use pre 2010 footage. Anything new I shoot will only play and burn off the PC with low sound and no L soundwave.
    I’m be really grateful to anyone who knows what I can do!
    Thank you,
    Tony Cook
    Mike Velte replied 16 years, 5 months ago 2 Members · 1 Reply
  • Mike Velte
    March 25, 2010 at 10:50 am
    WHat camera are you using?
    Typically audio with right channel only is the result of using an external mic or audio source that is only one channel. The “Fill Left” audio effect should result in filling the left channel. Correct volume is determined using the Audio Master Meter or the Audio Mixer.
