Activity › Forums › Maxon Cinema 4D › Noob question here, how to create another edge from an exisiting edge
  • Noob question here, how to create another edge from an exisiting edge
    Posted by Craig Ricker on April 23, 2012 at 1:42 am
    So I have an edge loop i’d like to make a copy of an move down the object I have.
    Is there a simple way to copy an edge, or an edge loop, to then use the slide tool to move to another location?
    Adam Trachtenberg replied 14 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 23, 2012 at 3:38 am
    The best way to do that is probably to use the knife tool in loop mode. You can also select the loop and use the bevel tool. As far as sliding, unfortunately the built-in slide tool can only handle one edge at a time, but there is a free plugin (Kiyamaslide) that works with edge selections.
