Activity Forums Apple Final Cut Pro Legacy None of my audio will render
  • None of my audio will render
    Posted by Nick Wolf on April 9, 2010 at 4:46 am
    I just started using Final Cut Pro 5 and I’m LOVING it. I’m working on ediing a sketch for my sketch comedy group and for some reason none of my audio will render anymore. I’ve tried everything I can, changing to mp3, creating a new sequence and starting clean, importing different audio, but none will work and unfortunately I’m not very computer savy. Can some one help? When I try to render the audio a little box pops up and all it says is “General Error” and that’s it, nothing else. Any ideas?
    John Fishback
    replied 16 years, 5 months ago
    2 Members · 1 Reply
  • John Fishback
    April 9, 2010 at 3:59 pm
    Your audio should be PCM 48k 16 bit. If it’s not, use an external program like QT Pro, ST Pro or MPEG Streamclip to convert it. Tru that with one clip and see if it helps. It’s also possible you have a corrupt clip. Also, it always helps to know your workflow – how you capture your media, where it’s stored, what hardware are you using?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
