Activity Forums Adobe Premiere Pro Non-working program timeline
  • Non-working program timeline
    Posted by Michael Mohr on May 1, 2009 at 7:26 pm
    Not sure if anyone can help me with this. I installed CS4 on a HP DC7100 cmt. Duo core machine with 2 gig of ram running xp pro SP 3 32 bit. Everything works — exept timeline playback on the PC monitor. When I hit play, the timeline just sits there. It doesn’t lock up or crash. If I set it to play out to the deck via firewire it plays just fine. Here’s the kicker. I installed CS4 on an identical machine with only SP2 and less ram using the on board vga and it played perfectly. Any ideas out there?
    Eddie Lotter replied 17 years, 4 months ago 4 Members · 6 Replies
  • Eddie Lotter
    May 1, 2009 at 9:18 pm
    This is almost certainly a graphics driver issue.
    Update to the latest version. If you are already at the latest version then try an older one.
    Cheers
    Eddie
  • Jon Barrie
    May 2, 2009 at 1:38 am
    If the audio setup isn’t working, soundcard driver failed or the hardware was switched to playback to the camera and not desktop the playback won’t work. Look at the audio issues.
    – Jon 🙂
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Michael Mohr
    May 2, 2009 at 2:57 am
    Thanks for the input. As far as graphics drivers, I’ve tried both on board and and an added card (Nvidia Quadro FX 540) Neither work. The audio may be an issue but both PCs were set up exactly with the same settings. I’ll double check the drivers to see what version I have and what is on the test machine. I’ll see what happens Monday and keep you posted.
  • Chip Doss
    May 4, 2009 at 2:09 am
    Make sure your running the latest driver for sure, I have a couple of customers that had this same problem and updating the video card driver solved the problem. One customer was using an old video card and replacing the card solved the problem (not sure why the first card did not work). We are finding that CS4 on Vista 64bit with 8 gigs of memory or more makes a huge performance boost. After Effects can breath easier with more memory too, for about $500.00 depending on your configuration, going to 64bit + memory is not all that much of a headache and actually gives you more time at home with the family.
    Chip Doss
    Chip Doss
    Edgemont Video, Inc.
    http://www.edgemontvideo.com
  • Michael Mohr
    May 7, 2009 at 2:30 am
    Eddie, Jon and Chip,
    Thanks for all the input. I finally found the problem. It wasn’t a driver problem. It was my lack of understanding ASIO settings. I had to uncheck the audio device in the input but keep it checked in the output. If both are checked the timeline won’t play. I guess I have to do a little reading so I undertsand this a bit more. I capture everything on this sytem with firewire so the input not being checked shouldn’t be a problem (I hope).
  • Eddie Lotter
    May 7, 2009 at 1:35 pm
    Thanks for posting your solution, I’m sure it will help others in the same situation.
    Cheers
    Eddie
