Activity Forums Square Box CatDV Non Drop Frame
  • Non Drop Frame
    Posted by Kurt Outwater on October 13, 2011 at 7:24 pm
    When I import a quicktime sequence without a timecode track into catDV it defaults to drop frame time code. Is there a way to change it to default to Non Drop?
    Rolf Howarth replied 14 years, 11 months ago 2 Members · 1 Reply
  • Rolf Howarth
    October 14, 2011 at 9:42 am
    There isn’t no. If CatDV encounters a 29.97 fps movie it will assume drop frame timecode so the wall clock duration of the movie is displayed correctly. If you want to change it to non drop you’d have to do so via the Tools > Change Time Base command.
