Activity Forums Adobe After Effects Non AE7 question – Wiggling a stroke
  • Non AE7 question – Wiggling a stroke
    Posted by Stone Reader on January 17, 2006 at 4:51 pm
    Hey guys, I know all the talk is going to be about AE7 today, but hopefully I can sneak in a non AE7 question.
    Is it possible to wiggle a stroke created on a mask/path, or even wiggle a stroke created using the standard paint tool, to get that “shaky animation” look?
    By “shaky animation”, I mean the look you can get when you use the Vector Paint tool in AE Pro and enable wiggling.
    Naveen
    Stone Reader replied 20 years, 8 months ago 2 Members · 2 Replies
  • Filip Vandueren
    January 17, 2006 at 6:52 pm
    instead of using the stroke filter, try using the scribble filter.
    enable one of the “edge”-fill types instead of the inside -option.
    then twirl open Edge-options and set the width to 1
    Adjust the stroke-options to control how curve-y the wiggle is.
    An unfortunate drawback is that Scribble always has an “angle”, and for some mask, this breaks the line.
    You have to experiment with that angle-value as different angles give quite different results, you’ll see what I mean.
    So, it does have some drawbacks, and depending on the shape of the path it might or might not work.
    A different approach might be to use a soft roughen edges on a normal stroke
  • Stone Reader
    January 18, 2006 at 3:52 pm
    Thanks! The roughen edges method actually works pretty well.
