Activity Forums Maxon Cinema 4D Noise Rendering Issue – Stopping Noise Movement
  • Noise Rendering Issue – Stopping Noise Movement
    Posted by Eric Guiliani on March 14, 2016 at 3:13 pm
    Hello,
    I have a plane with a simple material applied to it. The material has a diffusion option selected, and within that I have a noise texture applied. I need the noise to stick/bake to the plane so that when it scales or moves, it looks like its apart of the plane. No matter what I tweak, the noise either moves/fuzzes/animates. I just need it to stick and not animate! Any help greatly appreciated. Here is the file I created for help:
    9884_noisetextureissue.c4d.zip
    London Jones replied 10 years, 6 months ago 2 Members · 1 Reply
  • London Jones
    March 15, 2016 at 1:21 am
    I never really played around with diffuse, however, I figured out why it’s doing this. I’m not sure if you’ll be satisfied with this result but the space of the diffuse was on object. If you change that to UV (2D), it does a better job than before.
    To change it:
    Go to your diffuse properties under your material
    Select your texture
    Change the Space from Object to UV (2D)
    I hope this helps
