Activity › Forums › Adobe Premiere Pro › Noise reduction in PPRO
Eyal Gordin
June 4, 2005 at 5:26 amThanks for the info. I’m playing with it already…
EGEyal Gordin
Designer of the unique
http://www.framedmemory.com -
Norman Lafranchi
June 4, 2005 at 7:21 pmThere are degraining filters in Sapphire plugins… Combustion 4 also has a degraining filter which I think pretty much works the same as described above using blurring.
That’s the closest thing I’ve seen to denoising. What kind of noise do you have? If you have the budget you can take it to a transfer suite and do a tape to tape transfer with grain or noise reduction, if the facility has the right kind of machine.
Eyal Gordin
June 5, 2005 at 10:04 amNorman,
Thanks for the advice. I’ve tried blurring and although some of the grainyness goes away, the blurring defeats the purpose. I’ll check on the tape to tape idea.
EGEyal Gordin
