Activity › Forums › Adobe Premiere Pro › Noise reduction in PPRO
Posted by Eyal Gordin on June 3, 2005 at 4:25 amDoes PPRO has a noise reduction filter? I couldn’t find it, unless it carries another name but does just that? If there is, does it soften the image?
EGEyal Gordin replied 21 years, 3 months ago 4 Members · 13 Replies -
Aanarav Sareen
June 3, 2005 at 4:37 amActually, there are a couple of filters you can use. A good one is DeHummer. But, for extensive noise reduction, I would consider doing it in Audition.
Aanarav Sareen
Adobe Certfied Expert, Premiere Pro
https://www.asvideoproductions.com/video -
Aanarav Sareen
June 3, 2005 at 4:12 pmAh! Well, if you can post a screen grab, maybe we can help you out a little better.
Aanarav Sareen
Eyal Gordin
June 3, 2005 at 4:42 pmHi
Can I attach the screen grab to a post? How? Sorry for being green…
EGEyal Gordin
Designer of the unique
http://www.framedmemory.com -
Aanarav Sareen
June 3, 2005 at 11:47 pmUse ImageShack and post a link to that picture in your next post.
Aanarav Sareen
Jim Arcon
June 4, 2005 at 3:57 amThere is a plug-in included with PPro that adds noise, but I don’t think that PPro comes with a video noise reduction plug-in. (Mine didn’t anyway.)
You used to be able buy plug-ins like Video Finesse, BigFX, or Vixen that included an NR. I haven’t seen them in a while. After Effects has a GREAT noise reduction plug-in, but I don’t know if it will work in PPro. (or if you have AE.)
In a pinch, I have duplicated a clip and put it directly above the original, then blurred the topmost layer slightly, and then reduced its opacity. Used in combination with a levels or shadow/highlight adjustment saved some nearly unviewable (ancient VHS) stuff for me.
Eyal Gordin
June 4, 2005 at 5:14 amJim,
Very interesting idea. I’m very Photoshop Savvy but didn’t realized I can do the same things in PPRO. Do you mean just put a copy of the clip in video 2 and then apply the adjustments?
I’ll play and see if it makes a difference.
EGEyal Gordin
Jim Arcon
June 4, 2005 at 5:24 amJust put a copy of the clip in video 2 and then blur the topmost layer slightly (fast blur works). Then reduce the opacity of the top layer. You’ll be juggling between getting rid of the grain and too blurry.
FYI – nearly any technique that works in Photoshop translates to AE and somewhat to Premiere – except premiere doesn’t have transfer modes.
