Activity › Forums › Apple Final Cut Pro Legacy › Noise reduction in multitrack clip… tearing my hair out
Posted by Travis Roesler on September 28, 2011 at 9:44 pmI am trying desperately to reduce the noise on every clip in a final cut sequence. I know that I have to send to soundtrack pro as a multitrack project, but I have no idea how to get the noise filter to APPLY TO EVERY CLIP!!! I can only seem to do it one at a time as an audio file project. If I have 100 clips, it’s going to take me forever!!!
If someone could tell me how to reduce noise on every clip in a sequence, I could finally stop tearing my hair out.
Thank you for your help!
Travis Roesler replied 13 years, 11 months ago 4 Members · 11 Replies -
Phil Balsdon
September 28, 2011 at 10:33 pmYou can apply Noise Reduction and “Save As Applescript” in Soundtrack. In Final Cut choose “Send To > Soundtrack Pro Script > “WhateverYouSavedAs”
Or if doing a Soundtrack Multitrack apply your Noise Reduction. Then in the HUD window choose Show Presets > User Presets > click the + button bottom left and give the preset a name. On the next grab from same camera take open Noise Reduction go to “Show Presets” and apply the User Preset you just saved.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://philming.com.au
https://www.steadi-onfilms.com.au/ -
Travis Roesler
September 28, 2011 at 11:07 pmWOOOWWWW…. Ok, I haven’t tried it yet but lemme try to rephrase what you’re saying.
After I apply the noise reduction in soundtrack, I go to file>save as and I select “applescript”. Is there any way that I have to specify that I’m saving specifically the noise reduction?
Then, all I have to do in final cut pro is select ALL of my clips, and send to this applescript and it will know to reduce the noise in all of my clips?
If what you’re telling me is true… it would be absolutely fantastic.
The other method that you mention would still involve keying in by hand 30 different noise reductions…. it makes it easier, but it would still be a pain in the butt. I must get the comprehensive adjustment to work!!!! I’ll try this out right away and let you know how it goes!!!
Michael Gissing
September 28, 2011 at 11:55 pmUnless the background noise is the same on every clip, then you need a noise print for each clip.
Travis Roesler
September 28, 2011 at 11:57 pmYes, the noise is the same… its the same shot in the same room, when I refer to clips, I just meant the different segments in the timeline below.
Michael Gissing
September 29, 2011 at 12:07 amYou could edit the sound in STP and then create a mixdown of the track and noise reduce the whole track in one pass.
Phil Balsdon
September 29, 2011 at 12:23 amIf you are just sending each grab from your FCP timeline as Soundtrack Script it will open a new Soundtrack file each time you send each script.
This will take sometime with a lot of segmented files.If you have a lot of cuts in your timeline use the Multitrack method.
Travis Roesler
September 29, 2011 at 8:21 pmMixdown? I don’t even know what that is. I exported to a multitrack project and every attempt that I made to apply a noise filter to multiple clips in the project or to the entire sequence failed miserably. The “reduce noise” tab was greyed out every time.
Is this mixdown process complicated?
Travis Roesler
September 29, 2011 at 8:27 pmHey phil,
I’ve tried to use the multitrack method but I just can’t figure it out. There was a nice video tutorial that showed me how to do this to the single audio file but I couldn’t for the life of me find anything on a multitrack audio project.
I just don’t know the buttons to hit, what to select, or the basic process behind it. The more that I talk to you guys, the more I realize that I don’t know anything 🙁
I really appreciate all of your help
Phil Balsdon
September 30, 2011 at 12:14 amLarry Jordan has some really good Soundtrack tutorials that you can purchase and download online. Since buying them a few years back I’ve been much more confident about sending audio to Soundtrack rather than just making adjustments in FCP.
Rusty Cockrell
October 23, 2012 at 10:30 pmTravis,
I am having this very same issue right now. And I am about to PULL MY HAIR OUT! Did you ever figure out how to reduce noise across the entire sequence???? I’m doing it individually right now and it sucks! Any help would be much appreciated.
RUSTY
