Activity › Forums › Sony Cameras › Noise on Ex3 Shots
  • Noise on Ex3 Shots
    Posted by Tony Poole on February 25, 2012 at 7:46 pm
    Hi all,
    I am shooting with an EX3 using a Nikon 105mm macro via an adaptimax converter (am new to this camcorder and the adaptimax). Am getting a lot of noise in shots I have taken, as though using considerable amount of gain but the is turned off. Have bracketed shots 2 stops either side of what I think is optimal but all have noise. Have seen other shots with same setup on Vimeo and they are clean and crisp. Am recording to Ki Pro Mini (Apple Pro Res HQ).
    Any suggestions would be very much appreciated as I know the camera and lens are good and the operator is the problem!
    Tony Poole replied 14 years, 7 months ago 2 Members · 2 Replies
  • Michael Slowe
    February 25, 2012 at 10:15 pm
    What do you mean the gain is turned off. You can’t turn it off, only to either high, medium or low (H, M & L) on the gain switch. The actual levels are set in the menu. Maybe the settings are too high. Most people set the low gain at -3 which should give no noise at all. Even 0 or 9 give me no noise either.
    Michael Slowe
  • Tony Poole
    February 25, 2012 at 10:47 pm
    Hi Michael,
    thanks for the reply – guess I meant the gain was set to zero for the L setting. Will try this at -3 and see if it makes the noise go away, though if you can go to +9 with no problems not sure this is it……
    Cheers
    Tony
