Activity › Forums › Panasonic Cameras › Noise, kind of clicking like in background of DVX100B noise – any ideas?
  • Noise, kind of clicking like in background of DVX100B noise – any ideas?
    Posted by Ian Liuzzi-fedun on June 6, 2011 at 5:59 am
    Instead of describing it, I have posted it here:
    One is just the noise and the other is the noise with a concert in the background.
    Happens with line and mic selection. What is up?
    Chris Cottrell replied 15 years, 3 months ago 3 Members · 13 Replies
  • 13 Replies
  • Noah Kadner
    June 6, 2011 at 3:40 pm
    No link.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
  • Ian Liuzzi-fedun
    June 6, 2011 at 7:36 pm
    Sorry:
    liuzzifedunstudios.com/test
  • Noah Kadner
    June 6, 2011 at 9:07 pm
    Need more info- what sorts of mics, wireless systems, cables, etc. Sounds like the standard sort of noise you get when you don’t mix quite right i.e. your mics are so far away from the action you turn the level way up, etc.
    Noah
  • Ian Liuzzi-fedun
    June 6, 2011 at 9:36 pm
    I was feeding a sound board into my camera (line level). I have the same issue with an on-board mic. I have the same issue with my HVX200
  • Noah Kadner
    June 6, 2011 at 11:47 pm
    Again- need more info- what sorts of mics, wireless systems, cables, etc. Pretend like we’re not able to see your setup from here.
    Noah
  • Ian Liuzzi-fedun
    June 7, 2011 at 12:28 am
    No offense, but the setup shouldn’t matter. We did not notice this on the headphone out of the board. We used wireless ULX Shure systems and a VP-88 stereo mic. There was also another wired mic (not sure of the brand).
    We used a Tascam Digital board so the XLR out of that went right into the camera.
  • Noah Kadner
    June 7, 2011 at 12:46 am
    Sounds like line level audio being recorded as mic level. Or 50/60hz ground hum from electrical grounding. I.e. was the board plugged into a non-conditioned A/C power outlet- I’d guess probably. Or the more general hum you get from long cable runs/unbalanced audio etc. And you probably didn’t notice it when you were recording originally because the level is so low.
    If your concern is- is there something wrong with my camera- I doubt it. More like it’s just not an ideal audio setup that you had there or perhaps the cables picked up some interference. You should try a mixer with pad controls rather than going directly into the camera next time. What you have there is pretty fixable with a bit of judicious equalization and noise reduction in post though.
    Noah
  • Ian Liuzzi-fedun
    June 7, 2011 at 12:48 am
    How do you respond to both my DVX and HVX having the same symptoms when a shotgun is plugged in?
  • Noah Kadner
    June 7, 2011 at 5:06 am
    right exactly- nothing to do with the camera but a symptom from all the other stuff I already suggested. Ask on the audio professionals forum if you want more specific tips on how to mic that kind of setup next time.
    Noah
  • Ian Liuzzi-fedun
    June 7, 2011 at 5:07 am
    I don’t think you are understanding me. The mirophone that came with the camera (the small shotgun), when plugged in exhibits the same effect. I don’t see how that relates to the setup for the concert at all.
