Activity › Forums › Compression Techniques › Noise in dark areas FCPX -> Compressor 4
  • Noise in dark areas FCPX -> Compressor 4
    Posted by Alya Flanke on August 19, 2013 at 11:03 am
    Hello,
    I use FCPX 10.0.6 with Compressor 4.
    The problem which I am not able to solve is that whenever I export my project from Final Cut with Compressor, one dark shot always comes out with noise.
    The different grey tones (it’s in black and white shot with the canon 5d) do not seem to merge neatly but build separated zones.
    This is what it looks like:
    When looking at the same shot in FCPX however, it looks smooth and those lines are not there.
    This is the same shot what it looks like with Final Cut:
    I exported with the following settings:
    File Extension: mpeg
    Estimated size: 6.2 GB
    Type: MPEG-2 program stream
    Video Encoder
    Width: 1920
    Height: 1080
    Pixel aspect ratio: Square
    Frame rate: 24
    Frame Controls On:
    Retiming: (Better) Motion Compensated
    Resize Filter: Statistical Prediction
    Deinterlace Filter: Better (Motion Adaptive)
    Adaptive Details: Off
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Start timecode from source
    Field dominance: Automatic:
    Selected Progressive
    Average bit rate: 10 (Mbps)
    1 Pass VBR enabled
    Maximum bit rate: 15.1 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 12, Structure: IBBP
    AND
    File Extension: mov
    Estimated size: unknown
    Audio Encoder
    16-bit Integer (Big Endian), Stereo (L R), 48,000 kHz
    Video Encoder
    Width: 1440
    Height: 1080
    Pixel aspect ratio: HD (1440×1080)
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls On:
    Retiming: (Best) High quality Motion Compensated
    Resize Filter: Linear Filter
    Deinterlace Filter: Fast (Line Averaging)
    Antialias: 0
    Detail Level: 0
    Field Output: Same as Source
    Codec Type: HDV 1080p24
    Multi-pass: Off, frame reorder: On
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 0
    Key frame interval: 24
    Temporal quality: 50
    Min. temporal quality: 0
    Maybe someone knows the problem and can help me!
    If you need any more information please let me know.
    Thanks in advanced!
    Ivan Myles replied 13 years, 1 month ago 2 Members · 3 Replies
  • Ivan Myles
    August 20, 2013 at 5:33 pm
    Looks like banding and quantization artifacts. This behavior is inherent to high compression encoding. Here are some options:
    Encoding:
    – Increase the quality levels (I’m not familiar with HDV settings, but you might want to boost the minimum levels and maximize the upper levels)
    – enable multi-pass VBR
    – increase the encoding bitrate
    – reduce the key frame distance
    Editing:
    – add light grain or noise
    – replace the soft gradient with a texture or solid color
    Also, is the source material progressive or interlaced?
  • Alya Flanke
    August 20, 2013 at 9:30 pm
    Are the options that you suggest right for mpeg 2?
    Is multi-pass VBR the same as Two pass?
    Where do i find in compressor the key frame distance?
    Is there on the camera a precise option for shooting in progressive?
    I shoot with mark ii at 24 frame per second with pal system.
    I edited wit native camera format and the project in final cut pro it is in progressive.
    Could that be caused by an excess of Noise reduction plug in?
  • Ivan Myles
    August 22, 2013 at 4:21 am
    Note that my previous recommendations were not encoder-specific. I shall defer to other posters regarding instructions for Compressor.
    – Yes. The biggest factors will be bitrate and quality level.
    – For the purpose of this discussion, yes.
    – In your previous post refer to the MPEG parameter “Closed GOP Size” and the HDV setting “Key Frame Interval.”
    – I believe the Mark ii shoots progressive.
    Anything is possible, but the most likely causes are low bitrate and quality levels.
