Activity Forums Adobe After Effects Noise effect
  • Noise effect
    Posted by Menno Wisselink on April 13, 2016 at 2:26 pm
    Hi guys!
    Im wondering how to do these kind of noise effects you see in the picture below;
    + Was wondering how to add noise on just a certain part of an object, and how to let the noise track the movement!
    Many thanks,
    Menno
    Kalleheikki Kannisto replied 10 years, 5 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    April 13, 2016 at 5:08 pm
    The easiest method would be to build the noise right into the animated pieces (layers). Photoshop brush with some airbrush/noise/scatter-type settings would do it.
    Animated noise is a bit more involved. You’d either have to do three versions of each piece and circulate them, or precomp an animated fractal noise layer with a soft mask to each one of them.
    I’m pretty sure that a static (non-animated) noise will — aside from being the easiest — look best.
