Activity › Forums › DaVinci Resolve › node viewer window size
  • node viewer window size
    Posted by Declan Smith on October 29, 2014 at 6:32 pm
    Is there anyway to get the node viewer window full-size or be able to resize it / move it to a secondary display ?
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
    Marc Wielage replied 11 years, 11 months ago 2 Members · 1 Reply
  • Marc Wielage
    October 30, 2014 at 3:03 am
    In v10, you can eliminate the Gallery and increase the size of the Node window by clicking the little tiny black button on the lower left edge of the Node window. That will shove it more to the left. Shrinking the size of the Viewer screen will also allow a bigger screen. Resolve v11 has even more space devoted to these controls provided you use a 2-display setup, which I think can yield a screen-wide Node window for people who want to see if they can cram 99 nodes into a single shot.
