Activity Forums Adobe After Effects No Wiggler in Window Menu
  • Nate Vander plas
    January 27, 2007 at 7:48 am
    Are you referring to the expression called “wiggle?” If so, simply add an expression to the property you want to wiggle (option-click the stopwatch) and type: wiggle(A,B)
    A is the number of times it wiggles per second and B is how much/far it moves (obviously you have to put in numeric values for A and B).
  • Majorasshole
    January 27, 2007 at 10:57 am
    theres an interface for “the wiggler”
    If you don’t have the pro version it doesn’t come with “the wiggler”
