Activity Forums DaVinci Resolve No way to pan a Gallery still within a split-screen wipe?
  • No way to pan a Gallery still within a split-screen wipe?
    Posted by Robert Glanns on September 10, 2011 at 6:52 pm
    Sorry for having to ask this again, but the Resolve manual mentions the ability to reposition a gallery still, but does not say how to do it.
    I need to be able to pan a gallery still within a split screen wipe, when I’m using it to compare one shot to another. How do you do this in Resolve?
    Robert Glanns replied 14 years, 8 months ago 2 Members · 2 Replies
  • Kevin Cannon
    September 10, 2011 at 8:52 pm
    Click “reference reposition” from the dropdown menu, which should kick you over to the format PTRZ controls, only now they apply to your stills. I use the wave panel PTRZ controls at this point, but I imagine you could also start dragging slider.
    KC
    prehistoricdigital.com
    hardworkingpixels.com
  • Robert Glanns
    September 11, 2011 at 4:33 am
    Thanks Kevin!
    This is what confused me about the Resolve manual’s explanation of this feature. I knew that this was supposed to be possible in the Format tab, but it never occurred to me to use the PTZR controls on my control-surface to pan the still! I had been dragging the sliders in both the “Input” and “Output” sub-tabs, and was totally confused that only the main source clip would get panned, and not the still.
    It seems rather counterintuitive that the reference repositioning feature seems to be completely inaccessible via the Resolve UI and only works via the control surface. But I’m glad to learn that it works, in any case.
    Now, if I could only rotate the split, then I’d be even more happy!
