Activity › Forums › Audio › no volume
  • no volume
    Posted by Bodybuildingbs on March 30, 2010 at 8:56 pm
    Hello
    This is probably very simple but I cannot figure it out. I connected a samson mic to my computer to record some dialog. The computer is sealed off and there was no sound in the room.
    I speak clearly into the mic but when I play it back you can barely hear the audio. Its the same problem in both sound forge and audition.
    Any suggestions and thank you.
    Richard Crowley replied 16 years, 6 months ago 3 Members · 2 Replies
  • John Fishback
    March 30, 2010 at 9:45 pm
    It sounds like you’re plugged into a line level input instead of a mic level input. It’s possible you can switch the input to mic level in your computer audio settings. What kind of computer are you using? If you only have a line input, you’ll need a preamp. You plug your mic to the preamp input and the preamp out to the computer.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Richard Crowley
    March 30, 2010 at 9:46 pm
    HOW did you connect the mic to the computer? Do you know that the mic works? Do you know that the computer input works?
    I can’t see what the computer being sealed off or sound in the room has to do with this question?
