Activity Forums VEGAS Pro no video with MFX files
  • no video with MFX files
    Posted by James Redmond on May 17, 2012 at 12:47 pm
    new laptop i7-2670QM & NVidia GeForce GTX 670M video card, 16 gigs ram
    I just installed Vegas 11 build 683 64 bit onto new laptop.
    Strange thing is when I drop MXF files from either Cannon XF105 or XF305 or Nanoflash, the files shows up as audio only files – no video.
    If I render on another computer and bring back to this computer everything is fine. Is there a setting I am missing?
    Thanks for your insights. I can’t seem to figure this one out. James
    James Redmond
    Dynamic Videos, Inc.
    Rogers, AR USA
    James Redmond replied 14 years, 3 months ago 4 Members · 12 Replies
  • 12 Replies
  • Mike Kujbida
    May 17, 2012 at 2:48 pm
    Install the 32 bit version of Pro 11 and see if that helps.
  • Jeff Schroeder
    May 17, 2012 at 5:05 pm
    Have you installed Canon’s XF Codec. From their site it looks like the video portion is in a proprietary codec.
    Jeff
    2-Xeon X5680 @ 3.33 MSI Mobo 48GB DDR3 GTX 580 3072MB 16TB Attached Storage Win7 Vegas 11 x64
  • James Redmond
    May 17, 2012 at 11:39 pm
    I installed the 32 bit as you recommended. Strange thing is that on some of the MXF the video and audio showed on the timeline correctly. Not all files but some.
    Later when I tried using the 32 bit program, after rebooting the computer it did not show the video portion – was again like it was audio only.
    So installing the 32 bit program did not solve the problem. Thanks Mike!
    James Redmond
    Rogers, AR USA
  • James Redmond
    May 17, 2012 at 11:41 pm
    I have the Canon XF Utiity program. That program imports the files fine. I do not believe there is another program needed for Sony, but I am missing something. Is there another program or codex you are referring to? James
    James Redmond
    Rogers, AR USA
  • Jeff Schroeder
    May 18, 2012 at 1:39 am
    From a quick look around their site it seemed as though they have their own unique compressor. You should take a look at one of your files with a codec analyzer to see what it needs to function correctly in Vegas.
    get one here: https://cleansofts.org/gspot.html
    Jeff
  • Mike Kujbida
    May 18, 2012 at 2:17 am
    [James Redmond] “So installing the 32 bit program did not solve the problem. Thanks Mike!”
    James, it was worth a shot. Very strange problem you have 🙁
  • James Redmond
    May 18, 2012 at 2:24 am
    Thanks Jeff. I installed gspot. It shows that the video codec is installed. so very strange behavior…
    Again when I drop that file on the vegas timeline – no video….
    James Redmond
    Rogers, AR USA
  • Jeff Schroeder
    May 18, 2012 at 12:56 pm
    James,
    I don’t mean to insult you, but, have you ever installed or used a codec pack? This is really strange behavior you are having. My first thought is to look outside Vegas to what could be broken to cause this.
    Can you post a link to a small file that does not show video in Vegas? I would like to take a look at it.
    Jeff
  • John Rofrano
    May 18, 2012 at 2:07 pm
    [James Redmond] “Thanks Jeff. I installed gspot. It shows that the video codec is installed. so very strange behavior…”
    Is the codec a 32-bit codec or 64-bit codec. If it’s 32-bit it will never show video in the 64-bit version of Vegas Pro. So even though GSpot says it’s installed, it could just be the 32-bit version that’s installed.
    [James Redmond] “Again when I drop that file on the vegas timeline – no video….”
    It could be that Vegas is not expecting that codec in an MXF container although you did say that it worked briefly with the 32-bit version of Vegas which leads me to believe that it may be a 32-bit codec only. I would contact Sony and ask if this camera is supported. You might also want to ask Canon what you have to do to edit this footage with 64-bit applications (i.e., is a proprietary codec needed or not)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • James Redmond
    May 18, 2012 at 4:44 pm
    John, I’ve edited both the Canon MFX files and the Nanoflash MFX fies on my 64 bit desktop with Sony 64 bit, without any problems.
    I also can edit the footage with Sony Vegas 10, 32 bit without any problems. I am in the middle of an event, trying to figure this out.
    Thanks, James
    James Redmond
    Rogers, AR USA
