Activity › Forums › Blackmagic Design › No Video Playback with Decklink SP & FCP 7
  • No Video Playback with Decklink SP & FCP 7
    Posted by Matt Devries on March 18, 2010 at 10:50 pm
    OS 10.5.8
    FCP 7.01
    Decklink 7.5.2 (and 7.3.2)
    I can’t get video playback to work with Decklink and FCP 7. It stopped working when I upgraded to FCP 7 from v6. I can capture video fine, and I can playback audio from Decklink. If I use the Video Playback>Show Current command, I can even see a frame of video. But when I play the video, it sits on the frame. Otherwise, I just get black out of Decklink. This happens in both driver version 7.3.2 and 7.5.2.
    When I capture video, the Decklink output shows what it’s capturing. I’ve tried trashing preferences and toggling the External Video on and off. But I can’t find anything that helps. Any ideas?
    Matt DeVries
    Joshua Moss-o’brien replied 15 years, 8 months ago 2 Members · 1 Reply
  • Joshua Moss-o’brien
    January 20, 2011 at 6:01 am
    OS 10.6
    FCP 7.01
    DeckLink 7.9.3
    I am currently having the same issue although just updating to see if this solves the problem. i am very new at setting these up but it seem strange that i would get perfect playback when a sequence is sent to color but just the freeze frames in FCP. any help would be much appreciated.
    i am using HDMI output to 1080p 24fps 8bit. however i have played around with the settings and it seems to occur no matter what settings i use for output.
    Cheers
    “A photograph is usually looked at – seldom looked into.”
    Ansel Adams
