Activity › Forums › Adobe Premiere Pro › No video output thru TV Monitor
  • No video output thru TV Monitor
    Posted by Hector Melendez on April 6, 2005 at 4:01 am
    Hello folks…
    I’m just experimenting with PPro 1.5 trial version and the full version is on the way.
    I had been working with it for a about a week and I could see the video coming out to a TV monitor. The video card is the Nvidia Gforce FX 5200. But I had to make a recovery to my Pc and after that I can’t see the video into the TV monitor again. I had made all possible trouble-shooting but only see a blue screen. In spite of this I can see a video coming from Qtime or media Player at full in the TV. I had looked everything in Premiere and can’t find a solution… Does someone have a clue or solution?? Thks in advance
    Hector Melendez replied 21 years, 6 months ago 2 Members · 2 Replies
  • Stylz
    April 6, 2005 at 7:04 am
    Can’t help ya buddy. You can help me though. I have the 5200 as well. Question for you is how do you hook it up to a t.v.? A third party device/modulator or what?
  • Hector Melendez
    April 6, 2005 at 7:29 am
    Well if it is the same video card then you have to look at the rear of the PC. Near the RGB monitor cable it have an SVHS & composite connector. You can connect direct from here to a TV.
    After I wrote this post I did another look at Premiere and I found the way. In the right sequence screen small monitor there is a small arrow. In the bottom it say video playback settings. Open this and at the bottom select “Use direct 3D” Voila!
    Remember to select dualview in the deskstop/right click/properties/settings/advance/GeForceFX5200 tap/nView display.Look for the different settings in this place.
    Hope it help you
    Hector
