Activity Forums Blackmagic Design No Video Out In FCP with Intensity Pro
  • No Video Out In FCP with Intensity Pro
    Posted by Michael Gagliano on November 28, 2009 at 8:45 pm
    Hello,
    Im getting no video to my HD monitor within FCP with the Intensity card. Im getting audio though Ive tried everything, All cables are good, monitor works, Unless theres a secret button im missing
    Thanks Mike G
    Matt Campbell replied 16 years, 9 months ago 2 Members · 1 Reply
  • Matt Campbell
    December 8, 2009 at 6:42 pm
    Are your System Pref settings set correctly to how your outputting? Meaning if your using Y, RY, BY, you have to select that in the System Prefs, BMD control panel, output.
    Secondly, make sure you have one of the BM codecs selected in FCP under the view menu, video playback. Also make sure your external video is set to all frames.
    Thirdly, I found out that the Intensity Pro card should be installed in the 4th or top card slot on the back of your machine.
    Hope this helps.
    OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
