Activity Forums AJA Video Systems no video monitor during playback
  • no video monitor during playback
    Posted by Nick Lammers on December 16, 2009 at 3:32 pm
    Hi all. I have a Kona LHi-RO in my MacPro with FCP 6.0.6. I am editing an XDCam EX sequence and monitoring HD through the SDI port and also SD through downconversion on the composite port. The issue is this: monitoring is fine through scrubbing, trimming, etc. but when I actually play the sequence the video (on the monitor, not in FCP) freezes and holds the frame that the playhead started on. When I stop playback the monitor is updated to the “correct” frame. I have not knowingly changed any settings since when this was working properly. Thanks for any help.
    Nick Lammers
    Med21, LLC
    St. Louis, MO
    Nick Lammers replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    December 16, 2009 at 6:12 pm
    Reset your HD easy setup in FCP and make sure your composite output is set to secondary/525i in the Kona control panel.
    Jeremy
  • Nick Lammers
    December 16, 2009 at 7:22 pm
    Thanks Jeremy. You were right – I had a mismatch in the settings. I forgot that some of the material was 720p and the outputs were set for 1080i.
    Nick Lammers
    Med21, LLC
    St. Louis, MO
