Activity Forums Adobe Premiere Pro No video from timeline through GL2
  • No video from timeline through GL2
    Posted by Jeff Hough on July 5, 2008 at 11:07 pm
    I just recently moved everything from an old PC to an iMac that’s set up as a dual boot through Boot Camp. I always use my Canon GL2 to display video playback from the timeline to an external monitor. For some reason, it’s not working with the iMac. I switched back to the PC to try it real quick, and it worked like you would expect.
    The iMac is recognizing the GL2 when it’s plugged in, but it’s just not outputting anything through it to the monitor.
    Also, I tried capturing video from the GL2, plugged into the iMac, and that worked fine.
    Has anyone else had similar issues? I’m also not sure if this is posted in the right place. Should it be posted in an Apple forum? And just to be clear, the software I’m using is the Windows version.
    Jeff
    Jeff Hough replied 18 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
