Activity Forums Maxon Cinema 4D No text appears
  • No text appears
    Posted by David Mickolas on June 8, 2006 at 5:51 pm
    I’m trying to create some 3D text within Cinema 4D, but when I try, nothing appears in any of my windows. Any suggestions? I can make it in Illustrator, but it sure would be easier all in one program.
    Kelly Johnson replied 20 years, 3 months ago 3 Members · 2 Replies
  • Mylenium
    June 8, 2006 at 6:19 pm
    Text is created as splines which are a non-rendering geometry type when used by themselves. You have to put your text into a Extrude Nurbs object to define how C4D creates a hull from the splines.
    Mylenium
    [Pour Myl
  • Kelly Johnson
    June 8, 2006 at 7:11 pm
    Also, be sure you’re not selecting TrueType if you’re on a Mac. You might have to select a different font. If you don’t have both the screen and printer font, C4D usually doesn’t see the type.
