Activity › Forums › AJA Video Systems › No support for 1080/25p ?
Posted by Melvin Chong on October 27, 2005 at 1:55 amHi,
Does Kona offically support this format ? I can’t seem to find it under Easy setup.
Cheers.
Gary Adcock replied 20 years, 10 months ago 3 Members · 3 Replies -
Gary Adcock
October 27, 2005 at 2:36 pm[Darth Mel] “Does Kona offically support this format ? I can’t seem to find it under Easy setup.”
in the new world it is called 1080i50 / 1080i60 are the current naming conventions for 25 and 29.97 FPS content.
Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Francois Xavier
November 5, 2005 at 10:24 amGary, are you still there ? (Oct 27 post)
you wrote
[gary adcock] “in the new world it is called 1080i50 / 1080i60 are the current naming conventions for 25 and 29.97 FPS content.”Darth was asking about 1080/25p / reading you I understand that 1080i50 is progressive ?
Documentary Director & Editor
Paris /France -
Gary Adcock
November 5, 2005 at 4:48 pm[Francois X] “Darth was asking about 1080/25p / reading you I understand that 1080i50 is progressive ?”
Sorry Francois,
I am still here, I just missed it with my travel schedule.Here are the steps to create a 1080p 25easy setup.
1) Setup FCP with a Kona 2 1080 24psf easy setup.
a) Go to Easy setup menu ( ).
b) Make sure the SHOW ALL checkbox is checked.
c) Select one if the Kona 2 1080p 24 easy setups (uncompressed or DVCpro HD – your choice).2) Create a 1080p 25 capture preset.
a) Go to FCP audio video settings -> capture presets (tab).
b) Click on : Automatically makes a copy and puts you in the preset editor.
c) Rename capture preset to Kona 2 1080p 25.
d) Change FPS from 24 to 25.
e) Exit.3) Create a 1080p25 sequence preset.
a) Go to FCP audio video settings -> sequence presets (tab).
b) double Click on the chosen setting: Automatically makes a copy and puts you in the preset editor.
c) Rename sequence preset to 1080p 25.
e) Exit.4) Go to FCP audio video settings -> Summary and click on Setup>. Name it Kona 1080p 25 “codec name”. This easy setup is based on the new capture preset and sequence preset you created in steps 2 and 3.
Quit FCP and restart.
ga
Gary Adcock
Studio37
Chicago, IL USA
