Activity Forums Adobe After Effects No Sound Preview in After effects 7
  • No Sound Preview in After effects 7
    Posted by Sergio Bello on April 6, 2010 at 6:40 am
    Hi, I’m a total beginner in After effects. I have AE 7.0. I’m trying to preview and sound sync audio with video in real time. Is this possible with AE? I have read and watched numerous tutorials how to preview sound but all I get is a loud static. How can I fixed this issue?
    Sincerely
    Sergio
    Jeff Toste replied 16 years, 5 months ago 3 Members · 6 Replies
  • Michael Szalapski
    April 6, 2010 at 1:13 pm
    What kind of sound file are you trying to listen to?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Sergio Bello
    April 6, 2010 at 3:53 pm
    I experimented with every sound file that is allowed for import.
    Nothing seems to work for real time audio and graphic sync.
  • Michael Szalapski
    April 6, 2010 at 6:14 pm
    If all you’re getting is static, something is wrong in your setup somewhere. I’m assuming your audio works fine in other applications, yes? So check your audio output preferences. I don’t have AE 7 here at work, so I can’t check what options it offers, but I know there are settings for audio hardware in CS4 (what I have at work). If I remember, I’ll check on my old AE 7 machine at home tonight.
    – The Great Szalam
  • Sergio Bello
    April 7, 2010 at 2:40 pm
    Thank you so much! I checked my audio output preferences and it works after changing the Sample rate and size. Thanks Again!
    Sergio
  • Michael Szalapski
    April 7, 2010 at 5:39 pm
    Not a problem. 🙂
    – The Great Szalam
  • Jeff Toste
    April 14, 2010 at 8:12 pm
    I wish I had the same results. I’ve tried it all. Checking sound preferences on computer and after effects (both set to internal in & out). Using Ram preview. Audio is selected in drop down under composition/preview. I’ve brought in the audio as a separate file in addition to the .mov file. Nothing works.
    Any suggestions?
    I could use some help.
