Activity › Forums › Adobe Premiere Pro › no sound playback in source monitor
Posted by Dirk Dejonghe on August 30, 2011 at 10:33 amWhen I look at a clip in the source monitor, no audio can be heard. When I drag the clip in a sequence and play it, audio is OK. When dragging the same clip from the sequence back to the source monitor, audio is OK too. What is wrong?
Claudia TV Coach Wehnes replied 1 year, 2 months ago 4 Members · 7 Replies -
Jon Barrie
August 30, 2011 at 12:06 pmIt is possible that te clip hasn’t finished conforming yet. There is an indication of the conforming in the bottom right of the UI with a yellow bar.
At first the source didnt play the audio as the confining wad not finished yet. Once you added the clip to the timeline the conforming was done, then when you looked in the source again it worked because the conforming was done.
– Jon Barrie
Jon Barrie
aJBprods
Jon’s YouTube Tutorial Page
follow Jon with twitter -
Dirk Dejonghe
August 30, 2011 at 4:40 pmI even get this with the countdown leader generated right there and now. Drag it to the sequence, it plays the sound, drag it back to the source monitor from the timeline and it still plays. Only when going from the media bin to the source monitor then no sound at all.
Alex Udell
August 30, 2011 at 6:28 pmAre you using any kind of 3rd party hardware from Matrox, Black Magic, or AJA?
If so, check your preferences for the Source Viewer and you can select the device (as opposed to the default Adobe media player)
Alex
Dirk Dejonghe
August 30, 2011 at 6:39 pmI do have a Blackmagic PCI board Decklink HD installed but I use the ‘built-in line input/output’ (the minijack at the back of the machine).
The clips are usually imported and not captured on this system.
Dirk
Alex Udell
August 30, 2011 at 7:20 pmyep that’s what I’m talking about.
see “Player Setting Prefs” here:
https://help.adobe.com/en_US/premierepro/cs/using/WSAB1EDD0E-ADC2-4a10-B399-E809E588618B.html
Alex
Dirk Dejonghe
August 31, 2011 at 10:42 am -
July 13, 2025 at 5:41 pmI know this is a very old topic. But I have the same problem recently. No playing audio of the dji Pocket 3 clips in the source viewer. But perfectly in the timeline. What do I have to change in the prefs? I have a Blackmagic Ultra Studio Monitor 3g attached.
